New Combined ADaM Folder
Use this field to specify the name and complete path to the new folder containing the Analysis Data Model (ADaM) data sets for the combined study.
The Analysis Data Model Folder
The Analysis Data Model defines a standard format for presenting raw and derived data in a form that permits ready statistical analysis with a minimum of programming. Analysis data sets must contain all of the data needed for review and the data must be ready for analysis. Refer to the ADaM website for additional details about the Analysis Data Model.
In cases where the same domain is specified in both the ADaM and SDTM folders (for example, adae.sas7bdat in ADaM and ae.sas7bdat in SDTM), the ADaM data set is used.
If you leave this field blank, the ADaM folder is assigned to be the SDTM folder if adsl.sas7bdat exists in the SDTM folder, otherwise the ADaM folder is assigned to be the Supplementary Data Folder and adsl.sas7bdat is created as a copy of dm.sas7bdat in that folder.
Note: All ADaM data sets must be placed in the same folder prior to analysis with JMP Clinical.
To Specify a New ADaM Folder:
| 8 | Click and then navigate to the location of the data set. |
To View the Contents of the Folder:
| 8 | Click . |
