Number of decimals to display for summary statistics in tables
Specify the number of decimal places for reporting calculated summary statistics for the findings tables.
Note: The summary statistic for count, N, does not use decimals.
To Specify the Number of Decimal Places:
| 8 | Make sure that the Display Visit summary statistic tables for each findings test check box is checked. |
| 8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
