Include events or interventions experienced by at least this percent of patients:
Use this option to specify a minimum percentage value for patients experiencing an event or intervention. A variable for each unique value of an intervention or event xxDECOD is included as long as this percentage of patients (or more) experiences this level.
The default value is set to20%.
To Specify a Value:
| 8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
