Only include on-trial measurements
Use this option to filter the laboratory domain records to only consider measurements that are taken after Study Day 1 and are not flagged as baseline. This option is specified by default.
This option is applicable only when you Normalize laboratory values by: the Upper Limit of Normal. This option does not apply when normalizing by Baseline.
Note: This option is new in JMP Clinical 7.0. Previously, the Hy’s Law calculation included all laboratory measurements. If you notice significant differences in your results between version 7.0 and prior versions, you should uncheck this option and rerun the report to corroborate/validate you results.
To Select This Format:
8 Click within the check box.
