Summarize tests with this many levels or fewer:
Use this option to specify the maximum number of distinct levels or values a findings test may have to be included in the analysis.
Note: A findings test must have at least 2 levels.
To Specify the Cutoff:
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
