Filter to only include Target Lesions in numeric result summaries
Use this option to include target lesions only in the numeric summaries.
When this option is checked, the report algorithm attempts to find target lesion information based on values in the following SDTM identifying variables (in order of preference for detection): TRGRPID, TRCAT, TUSTRESC or TUORRES (via unique TRLNKID to TULNKID). If the values of the determined variable contains TARGET and does not contain values such as NEW, NON-TARGET, or NOT TARGET, then these records are only used for evaluating tumor result measurements for plots.
Note: If the application of this filter results in no records, then all measurements excluding those marked as containing NEW or NON-TARGET values (if found) in the identifying variable, are used.
When this option is unchecked, any record for the selected or determined TRTEST for analysis that has a numeric result (TRSTRESN) is included in the calculation and summary plots. Also, if the identifying TARGET information cannot be found, the output is labeled as "Measured Lesions", rather than as "Target Lesions" to make this distinction clear.
To Specify This Option:
8 Ensure that the box is checked.
