Display shift tables of baseline versus trial laboratory measurement elevations
Check this box to compute and display tables of subject counts and percentages (per treatment group) of laboratory elevations in reference to the upper limit of normal (LBSTNRHI) for measurements taken at baseline versus trial summary measurements.
This table can be interpreted as a categorized representation of the shift from baseline. Table cells can be selected to select subjects and see their locations in corresponding shift plots.
Note: This process doubles the number of columns in the output data set. If you have many laboratory tests and these tables are not desired in the output, this option should be unchecked to speed processing and results generation time.
To Specify This Option:
| 8 | Check the box. |
