ALT Elevation greater than
Use this option to specify the cutoff for alanine aminotransferase (ALT).
Values are specifed as multiples of the upper limit of normal (ULN). By default, this value is set to 3xULN. Values above the specified levels are considered indicative of possible liver injury.
To Set the ALT Elevation Cutoff:
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
