Default value for lesions marked TOO SMALL TO MEASURE
Use this option to specify a value to replace when TRSTRESN is missing and the TRSTRESC result has a value of TOO SMALL TO MEASURE. Per RECIST guidelines, this should be a value of 5mm.
The value recorded in TRSTRESU should be considered when setting this default value.
Note: The value of TRSTRESC has to exactly match that text string (case insensitive), any other reason/case of missing TRSTRESN results will not replace with a default value.
To Specify the Lesion Threshold:
8 Either enter the desired size in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
