Label Variable
Use this field to specify the variable from the Input SAS Data Set that is used to label all points in the plots.
To Specify a Label Variable:
8 Specify the Input SAS Data Set.
All of the variables in the specified input data set are displayed in the Available Variables field.
8 Examine the list of available variables.
8 Highlight the variable whose values are to be used to labels points in the output plots.
8 Click to add the highlighted variable to the Label Variable field, as shown below:
