There are a number of important differences between JMP and Excel or other spreadsheet applications.
Formulas are applied only to entire columns. Calculate Values with Formulas in Work with Your Data describes how to use formulas.
Understand Modeling Types in Analyze Your Data describes how data type influences platform results.
JMP does not have the concept of worksheets. Each data table is a separate .jmp file and appears in a separate window.
