All of the examples in the JMP documentation suite use sample data. Select Help > Sample Data Library to open the sample data directory.
On Windows: C:\Program Files\SAS\JMP\13\Samples\Data
On Macintosh: \Library\Application Support\JMP\13\Samples\Data
In JMP Pro, sample data is installed in the JMPPRO (rather than JMP) directory. In JMP Shrinkwrap, sample data is installed in the JMPSW directory.
To view examples using sample data, select Help > Sample Data and navigate to the Teaching Resources section. To learn more about the teaching resources, visit http://jmp.com/tools.
Help created on 9/19/2017
