The Bias Report shows a graph for Overall Measurement Bias with a summary table and a graph for Measurement Bias by Standard with a summary table. The average bias, or the differences between the observed values and the standard values, appears for each level of the X variable. A t test for the bias is also given.
The Bias Report option is available only when a Standard variable is provided in the launch window.
Help created on 10/11/2018
