You can select one or more data table cells and change the color to highlight a specific value. Right-click the cell or cells, select Color Cells, and select a color. If a color is assigned to a cell, right-click and select Clear Color to remove the color. You can also select the color black to remove the color.
Help created on 10/11/2018
