Right-click the header area, select Column Properties, and select the property.
Right-click the header area, select Column Info, and select the property from the Column Properties menu.
Select Cols > Column Info and select the property from the Column Properties menu.
Click Apply to add the column property or click OK to add the column property and close the column properties window.
Help created on 10/11/2018
