Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here
is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The conditional residuals are given as follows:
is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The conditional residuals are given as follows:Shows the conditional residuals plotted against the conditional predicted values of Y. You typically want to see the conditional residual scattered randomly about zero.
Shows the quantiles of the conditional residuals plotted against the quantiles of a standard normal distribution. Also shown is a bar chart of the conditional residuals. If the conditional residuals are normally distributed, the points on the normal quantile plot should approximately fall along the red diagonal line. This type of plot is also called a quantile‐quantile plot, or Q‐Q plot. The normal quantile plot also shows Lilliefors confidence bounds (Conover 1999).
Conditional Residual Plots
