Configuration Settings
Distribution Configurations
For Knot components, enter the Minimum Available Dependences. The Knot shape enables you to configure a k-out-of-n shape where the shapes that are joined have different distributions. The Minimum Number of Dependencies is k, the minimum number of paths leading to the Knot that need to function in order for the system to function.
Figure 10.16 Example of a Weibull Configuration for a K out of N Shape
Help created on 10/11/2018
