Select File > Database > Query Builder to display the Select Database Connection window.
If the desired data source is not listed in the Connections box, click New Connection to choose a data source. The method of choosing a data source depends on your operating system and the ODBC driver. See Connect to a Database for details.
Figure 2.29 Select the Database Schema
