Shows the proportion of defective items.
Shows the number of defective items.
p-charts display the proportion of nonconforming (defective) items in subgroup samples, which can vary in size. Since each subgroup for a p-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in a subgroup is Ni.
np-charts display the number of nonconforming (defective) items in subgroup samples. Because each subgroup for a np-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in subgroup i is Ni.
Note: To use the Sigma column property for P- or NP- charts, the value needs to be equal to the proportion. JMP calculates the sigma as a function of the proportion and the sample sizes.
Levey-Jennings charts show a process mean with control limits based on a long-term sigma. The control limits are placed at 3s distance from the center line. The standard deviation, s, for the Levey-Jennings chart is calculated the same way standard deviation is in the Distribution platform.
Help created on 10/11/2018
