Custom Design constructs a design that seeks to optimize one of several optimality criteria. (See Optimality Criteria.) To optimize the criterion, Custom Design uses the coordinate-exchange algorithm (Meyer and Nachtsheim, 1995). The algorithm begins by randomly selecting values within the specified design region for each factor and each run to construct a starting design.
The design obtained using this process is optimal in a large class of neighboring designs. But it is only locally optimal. To improve the likelihood of finding a globally optimal design, the coordinate-exchange algorithm is repeated a large number of times. Goos and Jones (2011, p. 36) recommend using at least 1,000 random starts for all but the most trivial design situations. The number of starting designs is controlled by the Number of Starts option. See Number of Starts. Custom Design provides the design that maximizes the optimality criterion among all the constructed designs.
Help created on 10/11/2018
