Displays a preview of the dashboard. Click Close Preview on the dashboard to return to the dashboard mode.
Windows (JMP): "/C:/Users/<username>/AppData/Roaming/SAS/JMP/<version number>/DashboardTemplates"
Windows (JMP Pro): "/C:/Users/<username>/AppData/Roaming/SAS/JMPPro/<version number>/DashboardTemplates"
Windows (JMP Shrinkwrap): "/C:/Users/<username>/AppData/Roaming/SAS/JMPSW/<version number>/DashboardTemplates"
Macintosh: "/Users/<username>/Library/Application Support/JMP/<version number>/DashboardTemplates"
Help created on 10/11/2018
