Select Graph > Graph Builder.
Figure 3.2 Points Showing Diamond Characteristics
Right-click the plot and select Points > Change to > Contour.
6.
(Optional) Click Done.
Figure 3.3 Contour Plot of Diamond Characteristics
The darker areas indicate a higher density of observations. In Figure 3.3, use the crosshairs tool to verify the following:
