Figure 6.18 Factors Outline
Enters the number of continuous factors specified in Add N Factors.
Enters the number of nominal factors specified in Add N Factors.
Adds multiple factors of a given type. Enter the number of factors to add and click Continuous or Categorical. Repeat Add N Factors to add multiple factors of different types.
Tip: When you have completed your Factors panel, select Save Factors from the red triangle menu. This saves the factor names and values in a data table that you can later reload. See Definitive Screening Design Options.
The name of the factor. When added, a factor is given a default name of X1, X2, and so on. To change this name, double-click it and enter the desired name.
To edit a value, click the value in the Values column.
