Changes to toolbars and menus are stored in customization sets, or plain text files. You open a customization set in JMP to import your modified toolbars and menus. The customizations are then shown in the Menu Editor. See Change Customization Sets for details about the menu customization files.
Select File > Open.
In the File name list, select All JMP Files (or JMP Menu Files) and then select the customization set.
Click Open.
