The Saturated degrees of freedom is m–1, where m is the number of unique populations. The Fitted degrees of freedom is the number of parameters not including the intercept.
The Lack of Fit table contains the negative log-likelihood for error due to Lack of Fit, error in a Saturated model (pure error), and the total error in the Fitted model. The chi-square statistic tests for lack of fit.
Help created on 10/11/2018
