The Mixture Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers in Introduction to Profilers for details about the availability of the Mixture Profiler in different platforms.
The Mixture Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu and select the models to be profiled. Then, select Mixture Profiler from the Profiler red triangle menu.
