Click Make Table to construct the table or tables that you selected in Output Options. In the table panel of the Choice Profiles table, there is a Choice script. Run the script and then click Run Model to analyze your experimental results.
Caution: Only main effects are added by the Choice script. Add interactions manually.
Help created on 10/11/2018
