μ is the Gaussian Process mean,
σ2 is the Gaussian Process variance,
Theta corresponds to the values of θk in the definition of R.
Note: If your report contains the note Nugget parameters set to avoid singular variance matrix, JMP has added a ridge parameter to the variance matrix so that it is invertible.
Help created on 10/11/2018
