Figure 6.19 Output Options Panel
The Run Order options determine the order of the runs in the design table. Choices include the following:
Click Make Table to construct the Definitive Screening Design data table.
Runs the DOE > Definitive Screening > Fit Definitive Screening platform. See The Fit Definitive Screening Platform.
Runs the DOE > Design Diagnostics > Evaluate Design platform. See Evaluate Designs.
Figure 6.20 Definitive Screening Design Table Showing Scripts
Help created on 10/11/2018
