Specify details for the output data table in the Output Options panel. When you have finished, click Make Table to construct the data table for the design. Figure 8.17 shows the Output Options panel for a standard design selected from the Design List. For a main effects screening design, only Run Order is available.
Figure 8.17 Select the Output Options
The Run Order options determine the order of the runs in the design table. Choices include the following:
Help created on 10/11/2018
