The Contour Profiler shows response contours for two factors at a time. Other factors can be set to specific values to show how this affects the contours. The interactive contour profiling facility is useful for optimizing response surfaces graphically. Separate surface plots for each response are also graphed. Figure 3.2 shows an example of the Contour Profiler for the Tiretread.jmp sample data.
Figure 3.2 Contour Profiler
