An important aspect of fitting generalized linear models is the selection of explanatory variables in the model. Changes in goodness-of-fit statistics are often used to evaluate the contribution of subsets of explanatory variables to a particular model. The deviance is defined as twice the difference between the maximum attainable value of the log-likelihood function and the value of the log-likelihood function at the maximum likelihood estimates of the regression parameters. The deviance is often used as a measure of goodness of fit. The maximum attainable log-likelihood is achieved with a model that has a parameter for every observation.
Help created on 10/11/2018
