Note: This option requires the Coloring role.
To customize properties such as the marker size, text size, and grid lines, right-click the 3D scatterplot and select Settings. The Settings window appears. As you modify the settings, a preview appears on the 3D scatterplot.
Figure 5.7 The Scatterplot 3D Settings Window
Help created on 10/11/2018
