To compute power, you make use of the noncentral F distribution. The formula (O’Brien and Lohr 1984) is given as follows:
F is distributed as the noncentral
and
is the 1 - α quantile of the F distribution with ν1 and ν2 degrees of freedom.
and
is the 1 - α quantile of the F distribution with ν1 and ν2 degrees of freedom.n is the number per group.
r is the number of groups.
μ is the overall mean.
σ2 is estimated by the mean squared error (MSE).
is the corrected sum of squares.
