You can rearrange or sort data table columns by their name, data type, or modeling type, or reverse the current order. To reorder columns, select Cols > Reorder Columns and select from one of the following options:
To first: moves the selected columns so that they are in the left-most position in the data table.
To last: moves the selected columns so that they are in the right-most position in the data table.
After: moves the selected columns so that they are after a column that you identify.
