Enter 100 for the Number of Simulations.
Enter 35 for the Simulation Usage for Torque.
Click Run Simulations to run 100 simulations of the experiment. This is to check to see whether the 100 units that you plan to test will be sufficient given your prior assumptions for the design.
Figure 21.9 Simulation Results
