Each time you use JMP is called a session. A saved session is a JSL script that re-opens documents and re-runs analyses to restore JMP’s state when the session script was saved. A saved session can help get you back to a previous state without having to manually re-open files and re-run analyses.
Help created on 10/11/2018
