Adds a k-out-of-n block shape that represents a group of n identical components that are connected in parallel. At least k of the n components must be functional for the block to remain functional.
Adds a standby block shape that represents a group of n identical components that are connected in parallel. Only k components are active, or performing work in the system. The remaining inactive components act as standby components that are activated when any of the k active components fail. The block must have at least k functional and activated components for the block to remain functional.
Adds a stress sharing block shape that represents n identical components that are connected in parallel. Components fail one at a time, and remaining components fail at a quicker rate. The block must have at least one functional component and the block must successfully reallocate stress across remaining components for the block to remain functional.
Help created on 10/11/2018
