For a response series {yi}, the general form for the ARIMA model is as follows:
t is the time index
B is the backshift operator defined as Byt = yt - 1
wt = (1 - B)d yt is the response series after differencing
μ is the intercept or mean term
φ(B) and θ(B) are the autoregressive operator and the moving average operator, respectively, and are written as follows:
at are the sequence of random shocks
The at are assumed to be independent and normally distributed with mean zero and constant variance.
The constant estimate δ is given by the relation:
In the case of Seasonal ARIMA modeling, the differencing, autoregressive, and moving average operators are the product of seasonal and nonseasonal polynomials:
where s is the number of observations per period. The first index on the coefficients is the factor number (1 indicates nonseasonal, 2 indicates seasonal) and the second is the lag of the term.
Help created on 10/11/2018
