Start this stored process executing in the background. This message is paired with End Run, which should also be called at some point after Begin Run to wait for the stored process to complete.
-1 = execution failed.
1 = not started.
2 = running.
3 = canceled.
10 = completed successfully.
11 = completed with errors.
Same as Run, except AutoOpenResults and NoAlerts are not supported. They are available on EndRun.
1 if deletion is successful, 0 otherwise (error message to JMP log).
Optional, Boolean. If True, the user is not prompted for confirmation before the attempt is made to delete results.
1 if the user clicks OK to dismiss the window, 0 if the user clicks Cancel.
Waits a specified amount of time (or forever) for a stored process started with Begin Run to complete. If the stored process is complete, retrieves the results, and opens them.
1 = not started.
2 = running.
3 = canceled.
Optional, Boolean. If True, results are automatically opened if the stored process completes in the time specified by MaxWait. If False, results are not automatically opened, and can be manually opened via the object returned by the Get Results message. Default is True.
Optional, an integer. Specifies the maximum amount of time in milliseconds to wait for the stored process to complete. If MaxWait is not specified, End Run waits forever for the stored process to complete.
Optional, Boolean. If True, error messages are sent to the JMP log rather than message boxes. The default value is False.
Optional, Boolean. If True, get only visible parameters. If False, get only non-visible parameters. If not specified, get both visible and non-visible parameters.
Optional, Boolean. If True, get only modifiable parameters. If False, get only non-modifiable parameters. If not specified, get both modifiable and non-modifiable parameters.
Optional, Boolean. If True, get only required parameters. If False, get only non-required parameters. If not specified, get both required and non-required parameters.
Optional, Boolean. If True, get only expert parameters. If False, get only non-expert parameters. If not specified, get both expert and non-expert parameters.
1 = not started.
2 = running.
3 = canceled.
1 = not started.
2 = running.
3 = canceled.
Optional, Boolean. If True, results are automatically opened when the stored process completes. If False, results are not auto-opened, and can be manually opened via the object returned by the GetResults message. The default value is True.
1 if successful, 0 otherwise (value can violate the parameter’s constraints).
Help created on 10/11/2018
