The table contains a Distribution script that constructs a Distribution report. This report contains histograms, quantiles, summary statistics, and simulation results for each column in the simulated results data table. In addition to the standard Distribution report, the report contains the following items:
The table contains a Power Analysis script only if you have simulated a column of p-values. This script constructs a Distribution report showing histograms of p-values and provides a Simulated Power report. See Simulated Power Report.
Help created on 10/11/2018
