The JMP Version() inquiry function returns the JMP version as a string. You might use this function to determine the JMP version and then run a script compatible with that version.
JMP Version(); // returns "14.0.0" in JMP 14
JMP Version(); // returns " 9.0.0" in JMP 9
Help created on 10/11/2018
