The p-value for the overall test of model significance.
The LogWorth of the p-value for the overall test of model significance.
The overall p-value adjusted for the false discovery rate. (See The Response Screening Report.)
The rank of the Overall FDR LogWorth expressed as a fraction of the number of tests. If the number of tests is m, the largest Overall FDR LogWorth value has Rank Fraction 1/m, and the smallest has Rank Fraction 1.
These columns contain p-values for tests of each model effect. These columns are arranged in a group called PValue in the columns panel.
These columns contain LogWorths for the p-values for tests of each model effect. These columns are arranged in a group called LogWorth in the columns panel.
Help created on 10/11/2018
