Launch the Fit Two Level Screening platform by selecting Analyze > Specialized Modeling > Specialized DOE Models > Fit Two Level Screening.
Note: If you created your design in the Screening Design Platform from a list of fractional factorial designs, the design table contains a script called Screening. Run this script to run the analysis directly.
