Apply a command to all similar reports in the report window. Hold down the Ctrl key and click the red triangle menu. For example, in a One-way analysis, if you hold down the Ctrl key, click the icon, and select Means/Anova/t Test, an analysis of variance is performed for all One-way analyses in the active report window.
