Select Rows > Row Editor.
Figure 3.21 Row Editor
displays the same window as if you had selected Rows > Row Selection > Select Where. Select one of the options from the Current Selection menu, and then highlight the column whose rows you want to select. Type in the value for which you want JMP to search. See Select Cells.
Help created on 7/12/2018
