JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Graph Builder
• Add Multiple Variables to Grouping Zones
You can add more than one variable to the
Group X
or
Group Y
zones. You place the incoming variable below or above the existing variable, depending on how you want your data to be ordered.
To add an additional variable to a grouping zone, simply drag and drop the variable into the drop zone.
When you drag a variable, a blue shape appears, symbolizing where the variable is added.
Example of Adding Multiple Variables to Grouping Zones
Example of Replacing Variables
