The following example uses the Fisher’s Iris data set (Mardia, Kent, and Bibby 1979). The Iris.jmp sample data table contains measurements of the sepal length and width and petal length and width in centimeters for three species of Iris flowers: setosa, versicolor, and virginica. To find characteristics that differentiate the three species, examine these measurements.
Select Graph > Parallel Plot.
Select the Scale Uniformly check box.
Click OK.
From Three Species in One Parallel Plot, you observe the following:
Click OK.
The following example uses the Big Class.jmp sample data table, which contains data on age, sex, height, and weight for 40 students. Examine the relationships between different variables.
7.
Click OK.
From Height and Weight by Sex, Grouped by Age, you observe the following:
