JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Capability Analysis
Capability Analysis
Evaluate the Ability of a Process to Meet Specifications
Capability analysis, used in process control, measures the conformance of a process to given specification limits. Using these limits, you can compare a current process to specific tolerances and maintain consistency in production. Graphical tools such as a goal plot and box plot give you quick visual ways of observing behaviors that are within specifications. Individual detail reports display a capability report for each variable in the analysis. The analysis helps reduce the variation relative to the specifications or requirements, achieving increasingly higher conformance values.
Examples of the Capability Platform
Contents
Overview of the Capability Platform
Launch the Capability Platform
Entering Specification Limits
Spec Limits Window
Limits Data Table
Spec Limits Column Property
The Capability Report
Goal Plot
Capability Box Plots
Capability Platform Options
Normalized Box Plots
Make Summary Table
Capability Indices Report
Individual Detail Reports
