JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Column Properties
Column Properties
Understanding Column Properties Assigned by DOE
When you construct a design using the DOE platforms, column properties are saved to the data table that contains the resulting design. This appendix provides detail about only those column properties that are saved to designs that the DOE platform constructs. Examples illustrate how each column property is assigned and used by the DOE platforms. Descriptions of column properties not assigned by the DOE platforms are provided in
Using JMP
Some of the column properties described in this appendix are useful in general modeling situations. To use the properties more generally, you can specify them yourself. This ability is particularly useful when your design has not been created by a DOE platform. Some of the examples in this appendix illustrate situations where you add a column property on your own.
Column Property Asterisks and Column Info Window
Contents
Adding and Viewing Column Properties
Response Limits
Response Limits Example
Editing Response Limits
Design Role
Design Role Example
Coding
Low and High Values
Coding Column Property and Center Polynomials
Coding Example
Assigning Coding
Mixture
Mixture Example
Factor Changes
Factor Changes Example
Value Ordering
Value Ordering Example
Assigning Value Ordering
Value Labels
Value Labels Example
RunsPerBlock
RunsPerBlock Example
ConstraintState
ConstraintState Example
